Full Version: Coolant Temp Gauge
golfpaul
Hi all.
2001 2.0 tdci
The coolant temperature never passes the 1/4 mark on the gauge - where would you advise looking first?
Could it be a dodgy sensor?
jamesm182
Thermostat?
Half way seems to be the norm for the cars I have had. Welcome to the club by the way!  :)
stooge75
when your car is running ,say on motorway does it still only sit at quarter way up?
golfpaul
Hi, no never goes above about a quarter.
The heaters are hot also.
Was thinking the sender, are they prone on this model.
Could it be the thermostat.
thanks in advance
FOCA
Hi all.
2001 2.0 tdci
It could not be a dodgy sensor - the cooling system is a traditional mechanical pump with a thermostat
there is a second (small) thermostat for the oil cooler, it comes off the waterpump casing - if it jams open it can cause serious overcooling
there is also an electric heater in the hose to the cabin heater
these engines take a long time to warm up in cold weather,/ are overcooled  especeally with the heater on (can take a lot of heat out of the system) and if its being driven sedately
golfpaul
When i said sender, i meant the coolant temperature sensor indicating an incorrect temperature.
what's the best way of diagnosing this issue?
cheers
FOCA
cheers
The temprature sensor reads the temprature of the head (the metal of the head) it sends this to the ECU and temp gauge, chances are it is working perfectly, and the low temp readings are from ACTUAL low temp readings,
the main thermostat controls the water temp
you could fit a water temp gauge so you would then know the water temp, seperate/ indipendant  from the one on the dash
Full Colour Version: Coolant Temp Gauge
