Full Version: battery light
hi all,
having a bit of an intermittent problem.
every so often my battery light will flash up for a second when im driving then dissapear again. It only ever does this a maximum of once each day, i can go for a few weeks sometimes with no probs.
Ive noticed it happens at any rev range.
stef
Whelk8891
[quote name='stef123' post='20601' date='Apr 17 2009, 08:10 PM']hi all,
stef[/quote]
...not wanting to be Captain Obvious, but have you checked the battery?
[quote name='Whelk8891' post='20606' date='Apr 17 2009, 08:31 PM']...not wanting to be Captain Obvious, but have you checked the battery?[/quote]
not had it load tested if thats what you mean as i havent had any problems with starting etc even through the winter. I have checked the terminals though, both clean and tight.
SierraYankee99
Could be a dodgy earth on the alternator. Check see if theres any corrosion on the connector that could be causing a intermittent problem.
[quote name='SierraYankee99' post='20667' date='Apr 18 2009, 06:30 AM']Could be a dodgy earth on the alternator. Check see if theres any corrosion on the connector that could be causing a intermittent problem.[/quote]
cheers SY, will check that out later today.
Full Colour Version: battery light
