bigcookie
April 18, 2009, 5:34 am
how do i change a front track rod end ball joint on offside on a ford galaxy 2.3 si 1998. can anyone help please
delboy
April 18, 2009, 11:59 am
slacken off the wheel nuts
jack the car up
remove wheel
remove the nut that holds the ball joint under the wishbone.
undo the nut that's on the track rod end
une a hammer to release the ball joint from the wishbone then
count the amount of turns it take to unscrew the track rod.
jit the new one the same amount of turns you just counted.
tighten up the nut on the track rod &
tap the balljoint onto the wishbone
tighten the nut onto the new wishbone & refit the wheel.
i would replace the whole part inck the arm of the track rod
phone this place for it. cost's about £15.00 inc postage i think
maybe best to do both sides as you may find if 1 is gone it wont be long for the other to go
www.buypartsby.co.uk
ford will be about £70.00 or near that as i was quoted that for my galaxy a yr or so ago.
should take about 30 mions approx.
i hope this helps you
bigcookie
April 18, 2009, 3:55 pm
thank you for your help . i will give it a try.
