Full Version: Help needed - Bushy things
MR5 H0LL
I was wondering if someone could help me. My Ka (2004 Collection) has been in for its MOT today and although it passed it did get an advisory for offside front lower suspension arm rubber bush deteriorated but not resulting in excessive movement. This means nothing to me the guy in the garage reckons it will be around £200, does this sound about right? It looks to me after a bit of research that its just a bit of rubber so £200 seems a lot.
What involved in actually replacing these?
Any help would be great thanks
delboy
hi m8
it's called a wishbone or lower suspension arm
ford will be £95.00 as i had to fit one last weekend.
best place to get it from it
www.buypartsby.co.uk
they will be loads cheaper about £20.00
it's quite an easy job to do
jack car up remove wheel
undo the bolt from under the arm behind brake disk & hit the bolt out
undo the rtack rod nut & hit that off the lower arm
then hit off the lower arm from the suspension (lump hammer for this )
then you will see the 2 bolst that hold the arm onto the body
remove them & hit them out &
remove the arm
then fit it all back together.
it's an hour job.
you may find it's best to do both sides at the same time
as it may make the handling of the car a little odd due to 1 side being tight & the other looser.
don't take to garage m8 best to do it yourself or ask a m8 to help you.
you will need axl stands for the job or similar as i don't trust the jack that comeas with the car
when you order your part it's best to phone it through as you will need to tell them if it's power steering or not
as they lower arms do differ m8
MR5 H0LL
Thanks for the advice. I wouldnt even know where to start trying to do it myself and thats probably why the man at the garage tried to rip me off, us ladies know nothing, lol! I might give Ford a ring and see how much they quote
Babybel
[quote name='MR5 H0LL' post='21359' date='Apr 21 2009, 09:13 PM']Thanks for the advice. I wouldnt even know where to start trying to do it myself and thats probably why the man at the garage tried to rip me off, us ladies know nothing, lol! I might give Ford a ring and see how much they quote[/quote]
I am like that. Dont have a clue about cars lol. Hate going to a garage though as I am scared they will rip me off as I know nout about cars and I bet they think they can make loads of money from me!
Wish I had did a mechanic corse at college so I had a rough idea on cars lol.
delboy
the part is £95.00
labout for 1 hour approx £75 or there abouts
ask at your local non ford garage what they will charge you
or you can ask them what they will charge if you supply the part as
most local garages will do that.
much cheaper than frauds...oops fords
Full Colour Version: Help needed - Bushy things
