Full Version: Diesel Injectors, How much?
Rugby Dave
Hi, i'm a new member here but have been a proud owner of my ford focus TDCi (DuraTorq 115ps) for a little over a year now. recently my car has been gettin a bit slugish, making smoke under hard acceration and also a ingination fault light comes on at motorway speeds! during a service in march the garage stated that the injectors are on there way out (93,000 miles). just wonder if the injectors giving up the ghost that could be causing the problems? the garage said it was the fuel filter (less than a year old part!) which they replaced to no resolve! so i'm thinking the injectors then. how much does a set of 4 bosch injectors cost? and where could i get them from?
Russ
[quote name='Rugby Dave' post='21494' date='Apr 22 2009, 07:51 PM']Hi, i'm a new member here but have been a proud owner of my ford focus TDCi (DuraTorq 115ps) for a little over a year now. recently my car has been gettin a bit slugish, making smoke under hard acceration and also a ingination fault light comes on at motorway speeds! during a service in march the garage stated that the injectors are on there way out (93,000 miles). just wonder if the injectors giving up the ghost that could be causing the problems? the garage said it was the fuel filter (less than a year old part!) which they replaced to no resolve! so i'm thinking the injectors then. how much does a set of 4 bosch injectors cost? and where could i get them from?[/quote]
What check did the garage do to test the injectors? Most diesels make some smoke on hard acceleration as does a dirty air filter. Have you tried some good injector cleaner in the fuel to clear the injectors? I'd try some and give it a good run on a motorway for a few miles before getting new injectors.
I would seek the advice of a diesel specialist before you go paying for new injectors. Not sure how much a specialist will charge to test the injectors but its far cheaper than buying a new set that make no difference.
Rugby Dave
[quote name='Russ' post='22455' date='Apr 30 2009, 04:43 PM']What check did the garage do to test the injectors? Most diesels make some smoke on hard acceleration as does a dirty air filter. Have you tried some good injector cleaner in the fuel to clear the injectors? I'd try some and give it a good run on a motorway for a few miles before getting new injectors.[/quote]
They plugged the car into a engine management tester, but just came up with a unknown fault in a closed loop! i think i'd give the injector clean a try, anyone know which one is best? i've been told redex is good
Full Colour Version: Diesel Injectors, How much?
