Jacko
March 8, 2008, 10:44 am
I have a 2001 Mondeo 2.0 TDDi. Iam getting the following intermittent problem with the ignition. When I turn the key it does not turn over or make any clicking sound but all the electrics come on. It has had a new starter motor and I replaced the alternator 2 months ago. If I go back to the car 30 minutes later it starts straight away and will be fine for a couple of days and then the problem repeats.
Have you heard of this before? Is it likely to be a loose connection?
Steve
March 8, 2008, 3:16 pm
welcome to FOC
Have you had the immobiliser checked?
kingswood
September 2, 2009, 3:37 pm
[post="716"]reply i think i have very similar problem to you[/post][quote name='Jacko' post='716' date='Mar 8 2008, 05:54 PM']I have a 2001 Mondeo 2.0 TDDi. Iam getting the following intermittent problem with the ignition. When I turn the key it does not turn over or make any clicking sound but all the electrics come on. It has had a new starter motor and I replaced the alternator 2 months ago. If I go back to the car 30 minutes later it starts straight away and will be fine for a couple of days and then the problem repeats.
Have you heard of this before? Is it likely to be a loose connection?[/quote]
dtmwelburn
September 6, 2009, 5:39 pm
From problems ive had with other cars in the past it definately sounds asif the immobiliser is on its way out, personally id get a aftermarket one installed to prevent further issues, hope this helps
