jokermarkel
May 13, 2009, 3:53 am
to save me some ££ going to get it looked out, would like ur advice peeps.
It looks like a fair new exhaust. but wen stationary with the engine running, or after ive revved the engine and the revs' drop, a "knocking" sound, not vibration, more like a bouncing knocking noise comes from inside my exhaust ..
if i push down with slight pressure on the exhaust pipe, the knocking stops. but it sounds like its coming from inside the main chamber. i can hear it somethings when im cruising along at a steady 30mph.
whats your thoughts guys, i've no ramp to reverse onto to check the car but i have a jack.
recon its a simple tighten something up? or somethings wrong!
thanks in advance for your help.
Mark
May 13, 2009, 1:28 pm
it could be that the exhaust requires adjustment on a bracket or securing clip, you really need a ramp to check it out. perhaps call into a local exhaust cnt to check the exhaust alignment.
Whelk8891
May 14, 2009, 2:47 pm
Probably just a loose bit of heatshield bumping on the top of the exhaust.
jokermarkel
May 14, 2009, 3:34 pm
[quote name='Whelk8891' post='24247' date='May 14 2009, 08:57 PM']Probably just a loose bit of heatshield bumping on the top of the exhaust.[/quote]
It was that mate, thats for your helps! just bent it witha screw driver and hammer, perfect.
thanks again
