Full Version: Focus 2.0 Timing Belt Question
marklord1983
Howdo guys quick question, im gonna get my timing and aux belt done soon and need to know if the water pump is driven by the timing belt? It's a focus 2007 2.0 tdci cheers chaps
Sent from my SM-N9005 using Ford OC mobile app
sambo87
I know the water pump is on the aux belt on the 1.8 tdci engine but I got told by ford that they recommend changing the cambelt either at 125000 or 10 years which ever comes sooner so I would ring them to check cheers Sam
marklord1983
Mines same interval time but then you hear of a few failing before this i've been quoted 95 for all the bits including water pump then 120 for labour, or I might just wait till 115000 miles but im starting to worry
sambo87
Something else always seems to break on mine every time it's got to go into the garage :-(
marklord1983
Touch wood mines been ok other than a few bits i've been quoted 230 all in for timing belt water pump and aux belt which isn't bad at all
marklord1983
Just an update guys, I had timing belt aux belt tensioners water pump and gear Box oil changed and it cos me 270 altogether which I fantastic I think.
that is one heck of a cracking deal!
marklord1983
I know couldn't believe it myself
goomba
Wen changing the belts and stuff. What shud b changed on a mk 2.5 1.8 tdci?
Sent from my GT-I9505 using Ford OC mobile app
Timing belt, aux belt and their pulleys are a minimum
goomba
Somebody mentioned idle tensioners. Dont have the faintest idea if dat needs to b replaced too
anything the timing belt touches ideally would be replaced. As that makes sure everything is replaced and done and less likely to fail!
Full Colour Version: Focus 2.0 Timing Belt Question
