Full Version: engine cuts out now and then
focus1.8zetec
hi all i have a problem with my 1999 focus 1.8.when i come to a stop every now and then the car dies all lights come on the dash i switch off then start it back up everything is fine i have been told by a garage that its a chip behind the clocks.????any ideas would be great many thanks.
ste
Si-Focus
[quote name='focus1.8zetec' post='24462' date='May 16 2009, 06:56 PM']hi all i have a problem with my 1999 focus 1.8.when i come to a stop every now and then the car dies all lights come on the dash i switch off then start it back up everything is fine i have been told by a garage that its a chip behind the clocks.????any ideas would be great many thanks.
ste[/quote]
Common for the cam shaft sensor to go and it does what yours is doing
no more than £20 from fords and easy job to do.
focus1.8zetec
hi thanks for that i will check it out where will i find this part and can you tell if its nackered by looking at it
many thanks
ste
Si-Focus
Cant tell by looking if its knackered,
location on the cylinder head near the cam cover,square multi plug going to it
if you have a fault code reader or can get one,a code may be stored and tell you exactly whats up
sr-performance
heyup mate, have a diagnostic check on it, it will tell you exactly what prob is,
Si may be right as the probs you have indicate a cam sensor prob.... cheap to buy, easy to fit... :)
steve
www.sr-performance.co.uk
cressws1
My 1999 1.8 Zetec does the same thing. Intermittently, Normally when crawling in slow traffic, Does exactly the same thing as it would if you stall, Engine cuts out, All dash lights on etc...
Might try this cam sensor job for the sake of £20 odd, Cheers.
focus1.8zetec
hi again and yes cressws1 that sounds just like mine its fine in good pace traffic but when crawling in rush hour and stuff this is when it tends to do it.
when you do the camshaft sensor please post a reply to let me no if it has solved the problem as i have been told by a garage its a chip behind the clocks so if it is the cam sensor its an eaisier job for me i dont fancy taking half the dash out
many thanks
ste
sr-performance
diagnostics will tell you straight away what prob is.... better than guessing.
steve
cressws1
[quote name='sr-performance' post='25849' date='May 28 2009, 04:59 PM']Hi,
steve
www.sr-performance.co.uk[/quote]
Mine shows as having no DTC Codes, Still does this.
sr-performance
[quote name='cressws1' post='27144' date='Jun 6 2009, 05:29 PM']Mine shows as having no DTC Codes, Still does this.[/quote]
did you have it on diagnostics?
steve
Full Colour Version: engine cuts out now and then
