lms1703
May 18, 2009, 2:20 pm
Can any one help. I have an 02 plate Mondeo 2.0 tdci (130) which has a lack of power. I have changed the EGR as I understand this is normaly the fault but it has not helped. Does any one else know what it could be.
sr-performance
May 18, 2009, 4:41 pm
Hiya mate,
any other probs? is management light on? is turbo spooling up? on tdci turbo is the vnt type and are prone for vanes sooting up and not throwing out.. have you thought about having a diagnostic check done?
steve
www.sr-performance.co.uk
lms1703
May 19, 2009, 2:02 am
Thanks for your advise I will book it into a garage for a diagnostic check. You said about the turbo would the diagnostic check show this fault or am I better off taking the turbo off and having a look for damage.
lms1703
May 19, 2009, 2:04 am
I also ment to say there is no lights on the dash except the normal ones.
sr-performance
May 19, 2009, 3:15 am
my turbo didn't show management light, i just checked everything and it was the only thing left, so it was taken off, stripped and cleaned.
have a diagnostic and they should be able to tell you if your turbo's boosting as it should be..
steve
lms1703
May 19, 2009, 9:32 am
Ok thanks for all your help.
Cheers Lee
May 19, 2009, 9:38 am
check for any splits in the intercooler pipe from the egr valve its a common place for them to go .
lms1703
May 19, 2009, 2:08 pm
I will give that a try. There is a small pipe that runs from the egr I have followed it and the end is not attached anywere to the engine. Does anyone know were it should go.
May 20, 2009, 10:06 am
i think you will find its a vacume pipe that should be connect to the manifold.
lms1703
May 21, 2009, 12:24 am
Could this be why I have a lack of power?
May 21, 2009, 10:10 am
this would not produce lack of power, as many people block the vacume pipe off. does it feel like the turbo is kicking in ?
lms1703
May 21, 2009, 3:25 pm
I does not feel like the turbo is kicking in. I have had it put on a computer and it has come up with.
P0403 - EGR Control Circuit
P0235 - MAP Sensor Circuit
Any ideas what this means and what I need to do to fix it?
sr-performance
May 21, 2009, 3:54 pm
po235 is turbo boost pressure sensor failure
po403 is as you've got. strip and clean egr and check wiring..
steve
lms1703
May 21, 2009, 4:25 pm
Where do I find this and is it expensive?
I can't see any wiring on the egr am I looking in the correct place? What is the best thing to clean it with?
I know these mite sould like silly questions but I am at a loss and really appreciate everyones help
May 22, 2009, 9:31 am
there wont be any wires on your egr valve as this was introduced on the euro 4 engines, going back to the vacume pipe there should be one connected to the turbo can you see anything, photos would be good.
lms1703
May 22, 2009, 12:08 pm
Thanks for the advise on the wiring. Would you know if the pipe goes into the top side or bottom.
May 23, 2009, 10:46 am
does you egr look like this
[url="http://passionford.com/forum/general-discussion/285739-disconnecting-egr-from-tdci-photo.html"]http://passionford.com/forum/general-discu...tdci-photo.html[/url]
lms1703
May 23, 2009, 2:51 pm
It look about the same but it is on the front left hand side when your looking from above.
May 24, 2009, 1:31 am
the following photo might help you can just see the vacume pipe attached to the round metal actuator of the turbo.
[url="http://www.flickr.com/photos/stuart166axe/2366333759/in/photostream/"]http://www.flickr.com/photos/stuart166axe/...in/photostream/[/url]
lms1703
May 25, 2009, 10:41 am
At last I have found were the pipe goes. Thanks 4 the help.
tdci lack of power
