Full Version: strange engine noise...whoosh from engine when accelerating
simba
Hi guys,
Yesterday i noticed a very strange noise coming from under the bonnet whilst driving.
It happens only when accelerating slightly hard.
Heres the issue:
the engine makes a 'whoooooshing' sound when accelerating slightly hard, normal acceleration is fine - it sounds like a burst of wind noise which is what i thought it was, but its definately not that as iv tested it many times now. What on earth is it? A turbo leak?
This morning about a minute after setting off to begin my 40mile journey to work it happened but the engine malfunction light also came on - so i thought poo!....pulled over, stopped engine waited a bit then started up again and fine - but the same noise still as i had to check.
Iv never had any warning lights come on to indicate anything needs topped up etc and Oil is fine as it was topped up 2 weeks ago.
mpg was also 47mpg instead of around 54 which is the norm for me....
advice?
thanks,
Sid_WRC
[quote name='simba' post='25992' date='May 29 2009, 09:59 PM']Hi guys,
Heres the issue:
advice?
thanks,[/quote]
sounds like you're turbo is going, the vans at work do the same, check the smoke coming outta your exhaust, if its a lot blacker than normal its definately your turbo
matty2008
Heres the issue:
advice?
thanks,[/quote]
sounds like theres a whole in the intercooler, or maybe if your lucky, just a pipe to the intercooler. if it is the intercooler, whats more of a concern is what caused it to blow a hole in it? when mine went, it was because it was filling with oil which was leaking from the turbo which was worn out. so you could end up needing a new intercooler and a new turbo.
i was advised that i could leave the turbo as it would last another few thousand miles, but if yours turns out to be the same problem, id advise you to change it straight away. after about 200 miles the turbo blow in spectacular fashion, it dumps the entire contents of the old straight into the engine via the intercooler. so the engine runs on this oil with the rev counter on the redline, with absolutley no way of stopping it,bellowing a massive black cloud of smoke. eventually the engine stopped dead and your left wondering if the engines just ceased up. it hadnt, but it was scariest thing thats happened to me in my 15 years of driving!!!
but thats a worst case scenario!!, it could just be a split hose or something
hope this helps, and i havent just scared you to death
Sid_WRC
[quote name='matty2008' post='29434' date='Jun 19 2009, 07:30 AM']hope this helps, and i havent just scared you to death[/quote]
this made me giggle lol
Texaspete81
I have the same issue with mine. I'm running a Focus 1.8tdci climate (07 plate, 62k) and get the whooshing noise at 1800rpm when I accelerate quickly, the noise stops once I settle out at speed and I have no loss in power (but I think my fuel consumptions down a little). I've checked all the hoses but found nothing untoward, also the noise isn't very loud but as I've heard it once I hear it everytime now.
I have no warning lights up and have tried the turbo cleaner recommended by the garage to see if that would clean out any blocked vanes.
Any suggestions where to look next without having to spend a fortune in the garage?
All help is hugely appreciated :)
could be a simple split in the air hose, 90% of the time this is what it is, if your turbo is behaving
skyshaddow
Hi all, i have encountered this issue twice in 4 months. First time it was a split pipe at the top 90deg bend. Replaced bend all good. This time th engine management light came on and stayed on. I took the wee sensor out of the steel pipe and double checked the recently replaced all was fine with it. Now the engine management light has gone out but the issue remains. The car still wants too boost every now and again. Any suggestions would b a gr8 help.
Mike
Sent from my GT-I9505 using Ford OC mobile app
Have you got any error codes by any chance?
have you checked the intercooler pipe for any splits or cracks?
skyshaddow
Hi guys yeah i found the culprit. Another split pipe on the underside, a right bummer to get too like. Still an excuse to spend time with the car at the weekend lol. Cheers for your help again.
Did you resolve it?
