starfire
June 3, 2009, 11:16 am
ford Fusion 1,steadly getting worse in past weeks,does it wether engine hot or cold.Difficulty engaging first or second gear,feels like somethings blocking gear stick movement.Then goes back to normal.Also crunching when engaging reverse.Engine will stall sometimes when pulling away.
June 4, 2009, 10:03 am
it could be that the linkage needs adjusting or it might be your clutch dragging, does your clutch pedal feel ok?
starfire
June 4, 2009, 6:41 pm
[quote name='mintalkin' post='26764' date='Jun 4 2009, 04:13 PM']it could be that the linkage needs adjusting or it might be your clutch dragging, does your clutch pedal feel ok?[/quote]
Yes the clutch pedal seems ok,the car has just been into local ford dealers for problem finding but they say theres nothing wrong.As i drove away from there it did it again,as i said before its a brief problems,that seems to be a sticky gear change.there is no gear crunching or problems with other gear selection and if i put the gear stick into neutral then try to select again its ok.
Stiff gears
