poacher
April 4, 2008, 7:24 am
Hi. I have a 54 Mondeo diesel Ghia X. It has just started to hold its revs between 1300. - 1500 as if the cruise control has taken over. The revs reduce on applying the brake or de-clutching, but if not the cars carries on in whatever gear I am in. Once this starts the tick over becomes lumpy at around 900 to 1000. Any ideas folks will be gratefully received.
poacher
April 16, 2009, 12:29 pm
[quote name='poacher' post='942' date='Apr 4 2008, 01:34 PM']Hi. I have a 54 Mondeo diesel Ghia X. It has just started to hold its revs between 1300. - 1500 as if the cruise control has taken over. The revs reduce on applying the brake or de-clutching, but if not the cars carries on in whatever gear I am in. Once this starts the tick over becomes lumpy at around 900 to 1000. Any ideas folks will be gratefully received.[/quote]
Come on folks somebody must have experienced this problem. No replies I can't believe it.
April 17, 2009, 9:08 am
it could be a few things, first check for any air leakes on the hoses, it could be a sticking or s*** up egr valve (these can be taken off and cleaned) an injector problem or even a sensor playing up.are there any codes stored ?
poacher
April 26, 2009, 12:26 pm
[quote name='mintalkin' post='20541' date='Apr 17 2009, 03:18 PM']it could be a few things, first check for any air leakes on the hoses, it could be a sticking or s*** up egr valve (these can be taken off and cleaned) an injector problem or even a sensor playing up.are there any codes stored ?[/quote]
Many thanks I will have a look.
scott
May 4, 2009, 7:00 am
Hi, may not be of any use to you now. But this is one of the issues i am currently having with my 2004 TDCi, Ford assure me it is an issue relating to the EGR valve needing cleaning/replacing.
Other associated problems are the car 'hunting for revs' at approx 2200rpm when coasting, increased fuel consumption and a lot of black smoke under acceleration. Ive got some spray which worked on my wifes Zafira when i cleaned her EGR valve (the car not the wife), so i'll try that before i replace it.
I got the spray off eBay if anyone is interested. this is the link below:
[url="http://cgi.ebay.co.uk/air-intake-inlet-valves-egr-valve-cleaner-diesel_W0QQitemZ160332324948QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item160332324948&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50"]http://cgi.ebay.co.uk/air-intake-inlet-val...%3A1%7C294%3A50[/url]
Mondeo 2.0 diesel
