Full Version: Clutch Fluid Leaking On Drive.
josh7195
Hydraulic clutch fluid leaking under car on to drive way, have to keep toppiing up resevoir every couple of days when computer sends me an alert and harder to get in gear.
sounds like the clutch slave cyliner has gone if you look at the bottom of the gearbox bell housing is it wet with oil if so the slaves gone so a new clutch and slave cylinder will be needed
josh7195
Sounds about right do you think im going to be paying about £900 ?
IINexusII
what mileage is your car? youll probably also need to replace the dual mass flywheel. all in (with DMF) it shouldnt cost more than around 600.
josh7195
About 55.000 sounds reasonable I supose
josh7195
Do you think 55.000 is way to soon for anything like that to happen?
IINexusII
depends on how you drive. bad clutch use will give issues like this very early
It can happen anytime really its likely a rubber seal on the slave cylinder it will eventaully go altogether so youll have no gears as happened to me no warning no slip it just went
Full Colour Version: Clutch Fluid Leaking On Drive.
