[quote name='Stu_CDX' post='1051' date='Apr 10 2008, 12:57 PM']Hi guys, I'm a new owner. I just bought a Ford Escort Serenade on a P Plate.
It's taken to over heating, crabbing and more. Details Below.
Overheating:
When the vehicle is not being driven at over 30MPH, the engine temperature gets really high. It goes right up to the red section and the fan doesn't come on. There's no mayo on the rad/oil caps and no signs of water loss. The fan doesn't come on at all.
Crabbing:
I don't know what to do here. When steering straight, it feels like its crabbing at like 5-10 degrees to the right. I don't like it!
Front Heated Screen:
Doesn't Work. Period, Switch doesnt light up or nothing.
Hand break:
Again, totally inoperative.
Brakes:
There's a small amount of brake fluid running from the resevoir to on to the master cylinder. They feel ok though...
Headlight flasher/Indicator switch makes the headlights flash whenever you touch it.
Anyone got any info
Overheating -
sounds like the electric fan switch or the fan it's self - I assume you have checked all the hoses and they are all hot and the heater is hot.
Take the plug off the switch and bridge the wires in the plug, If the fan comes on it's the switch or the wiring that's faulty.
If the hoses to the rad are cold then it will be the thermostat.
If the heater and heater hoses are cold - blocked matrix or an airlock.
Crabbing -
Probably suspension failure - broken spring and lots of other possible things.
Are you sure there is a heated front screen fitted?
Handbrake -
is there tension on the handbrake lever when it is applied?
headlight/indicator -
Probably faulty stock - replace it
