Full Version: StreetKa Air Con
Paul123
I have a 05 StreetKa. The air con hasn't worked for a couple of weeks... before I take it in for a service, is there anything I can do to check the air con over to help save me money?
The compressor not longer clicks into action when I press the air con button, although the light illuminates. I've check the fuse in the cab and it seems ok... are there any other fuses? Does anyone know where the relay is located... or does it sound like it just needs a re-fill?
Paul
delboy
[quote name='Paul123' post='29919' date='Jun 22 2009, 03:00 PM']Hi,
Paul[/quote]
hi m8
there is nothing you can do to check the aircon
the pump may not start dues to lack of gas to protect it's self .
i would not worry to be honest as it's most prob just gas (re-fill)needed
best to take to fords as they are about the same as other places & will do a clean aswell
get a price 1st
my area bristol charges about £55.00 (fords)
Paul123
Cheers Delboy, much appreciated.
Paul
Marko10
Hi Paul
Did you get to the bottom of this yet? My wifes 2005 Streetka has developed a similar problem. I havechecked out a lot of the system and so far everything seems to be working okay. There is power doen to th ecompressor but the clutch does not engage. I'm thinking that maybe a new compressor will be the answer....
Cheers Mark
delboy
hi guys
is it's no engaging it maybe just the lack or gas
it uses the pressure to get going so if it don't have any pressure it wont fire up.
you seem to be looking on the half empty side of things
it actually half full
take it to fords to get it checked out 1st
Marko10
I have looked at Ford TIS and there is a test sequence to check out the clutch without firing the engine up (which would override the pressure issue). You have to bypass the WOT relay etc. I have not had a chance to look at this yet, but will report back when I have. There are two pressure switches on the system which could cause the problem, but I suspect the magnetic clutch as there is power down to it. We'll see...
Marko10
Went through the test sequence the other day. Turned out to be the low pressure switch on the compressor (not the low pressure switch in the LP line). All sorted now.
1982robw
hey, how do you do the test sequence on the streetka aircon system? what did you do to the low pressure switch? my wifes aircon is absolutely rubbish..
Marko10
[quote name='1982robw' date='09 March 2010 - 06:26 PM' timestamp='1268154990' post='69945']
Hi m8,
sorry for not replying sooner - I don't look at this site very often. Anyway, the test sequence is fairly straightforward. It is on the Ford TIS (which is available on cd very cheaply on ebay I hear ;-))
My wife's streetka is a fairly late one and incorporates a switch into the side of the compressor itself (not all of them have this). It is pressed in and I suspect cannot be changed. Anyway, after following the test sequence through, I identified this as the problem by bridging it (it was the last check in the sequence, everything was okay until then). Once I had done that it fired into life. The answer is a new compressor really but it works okay as it is. When you say your wifes aircon is rubbish, do you mean it is working but not very cold? If so, I doubt that you have the same problem as me - more likely needs re-gassing.
Anyway have a look at service manuals on cd on ebay.
Hope this helps
Mark
1982robw
great info, thanks. so the ford TIS is a service manual guide?
1982robw
how much would a re-gass roughly be then? as it may well be that.
Marko10
[quote name='1982robw' date='05 April 2010 - 06:24 PM' timestamp='1270487671' post='76258']
Might be £80 or so at some fast fit places. However, Halfords do a kit for about £40. It includes a connector and pressure gauge. After that you can get refills for about £20.
As for the TIS - it is Fords Tecnical Information System. I have a spare cd that you can have if you pm me. I got one off Ebay that I couldn't get to load at first so the guy sent me another. However, it turned out to be a problem on my pc so I have two now. I think I only paid a few quid for it.
mark
Jcoventry
most local garages do a regas for £40-50 i think
grahamfromoldham
[quote name='Jcoventry' date='05 April 2010 - 08:50 PM' timestamp='1270500021' post='76307']
If anyone is in the Greater Manchester area, I use a guy who does air-con and he is mobile so it can be done at home. Last time he came to look at one of my Vauxhall's he spent a good two hours here and charged me about £70 which was well worth the money. There is more to air-con than simply re-gassing it. Its vital that leaks are checked for correctly with the pressure gauge, old gas removing then new gas injecting. If anyone needs his details, send me a message.
Full Colour Version: StreetKa Air Con
