steve67
June 23, 2009, 3:28 pm
hello, i have a 51 plate tddi focus, on start up first thing in the morning i have a small squealing noise from the engine that lasts for about 2-3mins and then disappears. any ideas? it's only in the morning!!!!
Whelk8891
June 23, 2009, 3:58 pm
[quote name='steve67' post='30171' date='Jun 23 2009, 09:38 PM']hello, i have a 51 plate tddi focus, on start up first thing in the morning i have a small squealing noise from the engine that lasts for about 2-3mins and then disappears. any ideas? it's only in the morning!!!![/quote]
Auxiliary belt, probably. Its a common complaint. Its a flat belt and when its worn, it can slip against the pulleys causing a squeak.
You can get some stuff to spray onto the belt to give it better adhesion, or you can replace the belt - better done at a garage cos I gather its not the easiest of maintenance jobs, plus the belt needs to be the right tension after refitting.
steve67
June 24, 2009, 9:13 am
[quote name='Whelk8891' post='30177' date='Jun 23 2009, 10:08 PM']Auxiliary belt, probably. Its a common complaint. Its a flat belt and when its worn, it can slip against the pulleys causing a squeak.
You can get some stuff to spray onto the belt to give it better adhesion, or you can replace the belt - better done at a garage cos I gather its not the easiest of maintenance jobs, plus the belt needs to be the right tension after refitting.[/quote]
thanks for that, the car is in for a major service next week , i'll get them to take a look.
sqealing noise
