[quote name='Whelk8891' post='32146' date='Jul 8 2009, 08:47 PM']I distinctly remember typing a reply to this, dunno where it went.
There are two noises that spring to mind which could be branded a 'beep'. There's the indicator tick sound, and the 'bong' sound like when you've got the door open, ignition off, with the lights on.
I would assume its the former - I had it myself ages ago. What I did was stick the car into diagnostic mode, then leave it 30s to exit diagnostic mode by itself and it hasn't happened since.
To go into diagnostic mode, open any door (I use the driver's door) and press the door switch on the B-pillar 8 times within 6 seconds. You'll hear a tick. At this point you can press the keys on the remote and you should hear further ticks if the car is picking up a signal (its not essential that you do this). Wait 30 seconds and you'll hear another tick.
If its not a 'tick', and its not a 'bong', then.... I dunno.[/quote]
Thanks for replying but no its a bleep just as i turn the key and just before ignition fires up
i have not left doors open or anything like that
the noise seems to come from the ignition area
thanks again
