emmad1604
July 14, 2009, 5:26 pm
Hi everyone
Just wondering if anyone can help me...I have a 2003 Streetka and on Thursday, I went to put my roof down and the button you press to open the compartment the roof fits into wasn't working. I then gave up trying to put it down and drove to where I was going. I parked the car and as I walked off I pressed the remote control to lock the car and a few seconds later the alarm started going off. It wouldn't let me lock the car with the remote without the alarm going off, so I had to lock it by putting the key in the door.
5 days later..I went to go out in the car today and it now won't start (I last drove it on Sunday). The radio and lights work and the car and boot will open with the remote control, but the electric windows won't work. Does this sound like a dodgy battery that has now died, or could it be something more like the electrics or starter motor?
I'm not sure if the roof and alarm is connected to the car not starting, or whether they are separate problems. Any help would be much appreciated.
Emma
blondie86
July 19, 2009, 9:56 am
[quote name='emmad1604' post='33023' date='Jul 14 2009, 11:36 PM']Hi everyone
Emma[/quote]
Hi emma
The alarm has gone off because the roof isnt up properly or back panel isnt shut right this happens to me when i put the roof up and down i just redo it again shuttin everything tight then it doesnt go off but with the switch not working at the side the connection has probaly gone just take it to a garage and they will fix it .With the car not starting maybe the battery has gone did you jump start it?
Otherwise i would take this to your local garage.
don't know as much as blokes do on cars lol but hope this helps.
blondie86
sholligan
July 20, 2009, 5:04 am
Hi Emma
Im having this exact problem with my car...only thing is when I called Ford they said I have to pay £45.50 to get them to diagnose what the problem is. Apparently its something to do with the battery needing to be changed and then the switch being reconfigured. It sounded like an expensive problem, let me know if you have any joy with yours.
With regards to your windows the garage near me said he's had 4 cars in the past 6 months with the window problem and its just a case or twisted wiring. He charges £15 but apparently it will only last 3-4months. He said for a long term solution get a new motor at about £80 from an independant or £271 from Ford dealer.
Hope this info helps, im literally passing on info i got from different garages on Sat morning. Hopefully someone can give us more accurate and precise information
emmad1604
July 20, 2009, 6:28 am
Thanks both for your replies. A friend that works for Audi came to look at the car on Thursday and said the battery was completely dead and needed replacing which I've done and now the car works fine, but the alarm is still going off and the roof switch still isn't working.
He pulled the carpet interior down in the boot to access the roof switch and did some electrical tests on the wires and thinks that there's a dodgy wire that needs replacing, but thinks it will be a long job as he'll have to get under all the carpet and everything to see where the loose connection/faulty wire is, so I think i'll leave it for the time being as it's not urgent and it could be quite costly.
As for the alarm...not sure why it's going off when I lock it still. I thought the same as you, that it was because the compartment wasn't shut properly as I have to redo it sometimes as well, but we managed to put the roof down by reaching the latch to release the compartment through the boot and made sure it was shut properly but it's still going off. Maybe because the compartment switch isn't working, it senses/thinks that it's not down properly and therefore the alarm goes off? Who knows, but when I find out I'll let you both know!
Thanks for your help
Emma
emmad1604
August 18, 2009, 8:58 am
Update on the car situation....the car has been running fine for a good few weeks now with the new battery, but the alarm still goes off when I lock it on the remote and the roof switch still doesn't work - haven't been able to get this fixed yet as can't afford it at the moment.
However, I haven't driven the car for a few days now and I went to go out in it today and the battery is completely dead again, the same thing that happened a few weeks ago when I first posted on here, but this is now a new battery. Something must be draining it and I'm thinking it must be something electrical linked to the alarm and roof switch.
Anyone got any ideas what it could be?
Thanks, Emma
gaz6076
August 18, 2009, 1:31 pm
The battery going flat is probably because of the faulty switch or the fact that your alarm keeps going off (could be both)
I'm not very clued up on the electric side of things but it sounds like the switch is causing the problems so I would start by trying to eliminate that first.
Ask your friend to disconnect the switch or bridge the connections for you and see if that stops your alarm going off.
