Trouble1212
July 22, 2009, 7:26 am
Hi everyone. Just wondering if anyone can help on a couple of topics.
1 - When I put the key in the ignition and turn it, nothing happens. When I turn it back towards me - all the disply needles shake. This happens very randomly... every 2 or 3 days. After a few tries of turning the key back and forth - hey presto!!
The var is currently in thr Ford garage who say there is nothing wring with it.
2 - A second point is the heating fans. They are really loud... is this normal?? Again - the garage seems to think so.
3 - Finally... the rear light is forever misted up and they have quoted me £116 to replace? Can I do this myself? (Well - get fiance / brother / dad to do it?) :-)
July 22, 2009, 9:34 am
its hard to comment on the first two problems without inspection, as for the rear light it must be condensation which is usually caused by a poor seal to the bodywork. you could remove the light cluster, dry it out with a hairdryer and then refit applying some sylicone sealent on the cluster to get a good seal to the bodywork.
Trouble1212
July 23, 2009, 9:03 am
[quote name='mintalkin' post='33824' date='Jul 22 2009, 03:44 PM']its hard to comment on the first two problems without inspection, as for the rear light it must be condensation which is usually caused by a poor seal to the bodywork. you could remove the light cluster, dry it out with a hairdryer and then refit applying some sylicone sealent on the cluster to get a good seal to the bodywork.[/quote]
That sounds like a much cheaper option - I will do that! Thank you for your advice.
With regards to the engine problem, I am collecting the car today. Ford have not done anything with it so if it happens again then I will try another garage.
Thanks again!
Poorly Streetka
