tdci stevie
July 27, 2009, 2:27 am
2004 2.0TDCi 130 55k, having problems with idle it seems like its hunting - getting it jump from 720rpm - 755rpm when idling, its also hesitant when pulling away in any gear its like a 2-3 second pause before you get the power....?
This is me first TDCi so am new to the engine, have just come from a vectra 2.0 DTi.
Also get a rumbling noise when de-ecelerating, changing gears, pulling off in say 2nd/3rd gear.....the noise only stays for about 5 seconds at a time....?
The car had been sat up since April 2009 and i purchased it Saturday 25 July 2009, so its not been run for a good 3 months, nor do i know when it was last serviced, so I gave it a full service yesterday and changing the diesel filter made me flaten the battery trying to start it... so on charge it is...
Any help with these couple of niggly problems would be much epriciated
Bobalob
July 27, 2009, 11:32 am
[quote name='tdci stevie' post='34545' date='Jul 27 2009, 08:37 AM']2004 2.0TDCi 130 55k, having problems with idle it seems like its hunting - getting it jump from 720rpm - 755rpm when idling, its also hesitant when pulling away in any gear its like a 2-3 second pause before you get the power....?
Any help with these couple of niggly problems would be much epriciated[/quote]
after changing the fuel filter you need to actually pre fill the new one it with diesel or it'll never start in a month of sundays. and the rumbling noise could be the accesory drive belt tensioner. ford brought out a T.S.B (Technical Service Bulletin) about them. sorry can't think of any thing for the rough running.
tdci stevie
July 28, 2009, 12:15 am
Just found out the hard starting after filter change was a dodgy new filter was a cheap pattern part and pipes didnt snug fit over, so off to ford today for original...
Going for M.O.T today hopefully that might shed some light on the nosie thats coming from around the passenger side front
tdci stevie
July 29, 2009, 2:21 am
Got it M.O.T'd today went straight throungh, engine idles alot better since the full service, but a little bit hunting revs may drop from 760 rpm to 735 rpm roughly....? someone suggested the egr may need cleaning out to improved engine breathing....?
Have got a Sealey diagnostic tool and there is no codes present or pending....?
Any suggestions must appreciated.
Thanks Steve.
fordtech
July 29, 2009, 4:31 am
Clean out the egr valve and the give it a damn good ragging up the motorway to clear it out , they were never the smoothest idlers though.
tdci stevie
July 29, 2009, 5:17 am
will be cleaning out EGR valve tommorow and put some STP injector cleaner in and give it a good boot hopefully sorts my problem - would the inlet manifold also need taking off and cleaning or could i get away without...?
Does anyone know how hard the auxialry tensior pulley/idler pulley is to change its a bit rattly (heard theres a upgraded/modified one)....?
tdci stevie
July 31, 2009, 5:00 am
EGR cleaned now performance is much improved still got rattly noise from around engine on idle...?
tdci stevie
August 5, 2009, 2:00 am
Popped in fords yesterday and they said the engine hunting was down to auxilary belt - tensinoner pulley and crank pulley , he reckons theres a modified one of each belt/tensioner & pulley....?
He said it wasnt that bad and i should put up for it at the minute but its one of those niggly problems.....
Does anyone know if its nessacary to change all 3 parts or could i get away with just belt....?
August 6, 2009, 10:54 am
fords tsb 18-2005 for a faulty accessory drive belt recommends replacing all three.
