I own a 1994 Granada 2.0i Ghia X Auto. Its generally a very good example, but recently its developed an odd fault.
At speeds over 50mph, and when applying a very small amount of left hand lock, the o/s front wheel wobbles badly, as if it was terribly out of balance.
Anything more than slight lock at the same speed, the wobble goes away. The right hand lock is fine.
If you put the brake on while its wobbling, then the wobble goes away.
I've jacked the car up and checked for play in everything and there is nothing apparently wrong.
Anyone any suggestions?
Thanks in advance
