MERCIAN
July 29, 2009, 7:10 am
I own a focus tddi estate and recently I have been getting a humming/droning noise when I reach 50mph ( it is literally bang on 50mph). It subsides slightly past 50mph but does carry on.
I recently had two new tyres on the front, one of which was not balanced ( but i dont think noise started immediately after fitting.)
I have also had two front wishbones fitted at the same time.
Garage has checked wheel bearings and they are okay.
Any ideas?
sr-performance
July 29, 2009, 9:12 am
hi mate, make sure your tyre's are not out of shape, it does happen!!
MERCIAN
July 29, 2009, 3:16 pm
[quote name='sr-performance' post='35131' date='Jul 29 2009, 03:22 PM']hi mate, make sure your tyre's are not out of shape, it does happen!![/quote]
Thanks for the reply.
Noise is almost certainly coming from front of car. There is no vibration connected with the noise and no noise/vibration from gear box.
sr-performance
July 29, 2009, 3:22 pm
If you jack a wheel up and spin it you can usually see if its out of shape...
MERCIAN
July 29, 2009, 4:55 pm
[quote name='sr-performance' post='35188' date='Jul 29 2009, 09:32 PM']If you jack a wheel up and spin it you can usually see if its out of shape...[/quote]
ok will try it
bill07
July 30, 2009, 3:54 am
first you should always get the wheels balanced,it could be causing all kinds of problems,think how much force could be created by 5 gram weight spinning on the end of a piece of string at that speed.
second what tyres did you fit, if they were cheep and nasty they are proberbly the problem.
MERCIAN
July 30, 2009, 6:43 am
[quote name='bill07' post='35293' date='Jul 30 2009, 10:04 AM']first you should always get the wheels balanced,it could be causing all kinds of problems,think how much force could be created by 5 gram weight spinning on the end of a piece of string at that speed.
second what tyres did you fit, if they were cheep and nasty they are proberbly the problem.[/quote]
One was a budget tyre and one a Firestone. Firestone( never used ) was my spare so tyre place just fitted it without balancing it.
I am embarrassed to say that I havent checked the Firestone pressure yet
bill07
July 30, 2009, 12:09 pm
budget tyre can make alot of road noise,but so can low tyre pressure so check all the tyres.
MERCIAN
July 31, 2009, 6:58 am
[quote name='bill07' date='Jul 30 2009, 06:19 PM' post='35371']
[/quote
Have checked all four tyres, rear passenger side was only 20psi. Have sorted it but still getting noise at 50.
Will get tyres rebalanced at weekend.
MERCIAN
August 6, 2009, 6:36 am
Both front tyres didnt need balancing!
So can just assume that budget tyre is culprit.
Noise is much more noticeable on some road surfaces than others so must be " crappy " budget tyre.
Get what you pay for I suppose!
