Full Version: vibration though steering
bud1234
i have a fORD MONDEO DIESEL HATCHBACK 2.0TDCi 130 had the wheels balenced and tracking looked at but get vibration though the steering at speeds of 40 mph up to 70 mph even 80 any one knows whats up
Fox
Hi, Try checking that your front disks are not worped, or the all the joints connected to the hub i.e wish bone, anti roll bar, track rod ends (steering arms) that should help
Fox
jock0909
Dodgy tyres, wheels out of shape or balancing done incorrectly.
Swap the front wheels to rear and rears to the front
stuz
if it is the disks when you stop put your hand near the wheel and you will more then likely feel a lot of heat but i doubt very much it is that i think it is more then likely that the garage you went to did not do your tracking and ballancing just fucked you off with a top up on your power steering fluid if it was the brakes you would only realy expeirience the tremble on slowing down
vinnyvangough
I know that the bushes in the lower arms on the escorts wear out for a past time and cause these problems, maybe worth a check of all the joints around the lower arms.
SierraYankee99
I'd guess on a buckled wheel pal. Swap front wheels onto back and back onto fronts. If you're still having the problem look at bushes etc as suggested but I'd like to bet that would cure it. If it does you'll need to source a new wheel.
tim4ford
[quote name='bud1234' post='1261' date='Apr 28 2008, 03:55 PM']i have a fORD MONDEO DIESEL HATCHBACK 2.0TDCi 130 had the wheels balenced and tracking looked at but get vibration though the steering at speeds of 40 mph up to 70 mph even 80 any one knows whats up[/quote]
I have vibaration coming up mine too dont know yet mite take it to the local garage mine hits in at 70mph
Turbo weasel
Did you have just the front wheels balanced? I believe that an out of balance rear wheel can also be felt through the steering.
If a wheel was buckled I would have thought they would have brought that to your attention - but no guarantee.
Russ
[quote name='Turbo weasel' post='8970' date='Dec 30 2008, 10:48 PM']Did you have just the front wheels balanced? I believe that an out of balance rear wheel can also be felt through the steering.
If a wheel was buckled I would have thought they would have brought that to your attention - but no guarantee.[/quote]
Sounds more like the balancing was done incorrectly in the first place. Seeing as u have just had them done take it back and tell them it's worse than when you brought it in, they'll check them again!
Full Colour Version: vibration though steering
