Full Version: Headlight warning
redspecial2000
newbie here, so go easy on me!
Having just purchased a 58 plate Ford Focus Zetec 1.6 Petrol Ive already left the sidelights on in the car twice. Should there be an audio warning to let me know that the headlights were on when I left the car?
Thanks!
Micro
[quote name='redspecial2000' post='36702' date='Aug 10 2009, 07:59 AM']Hi,
Thanks![/quote]
There is indeed a "headlight left on" warning sounder in my mums Ford Focus Zetec 1.6 (2002). However the side lights do not trigger it iirc (will check tomorrow).
Does it make mention of it in your manual?
alz
The lights on sounder.. comes on with the key out and drivers door open, works with side and headlights that how it works on my focus 1.8 tdci estate.
patkin
Mine's an 06 1.6 Zetec petrol and there is an audible warning (intermittent beep) for side or headlights on. Mine works when driver door is opened with key in 'off' position
Rousey
I have the same problem on mine. Did you ever find a solution
I believe there is a little relay somewhere that produces the sound either under the column or more likely in the passenger side fuse box
Check fuse 137 in the passenger fusebox.
NorthSussex
[quote name='patkin' timestamp='1250277923' post='37372']
[color=#0000ff][size=5][font=comic sans ms,cursive]Yep, same on the 1.8 petrol Titanium Estate, 59 plate.[/font][/size][/color]
DJ_Andy_M
Are you sure you're not turning it to parking lights? These will not sound a warning and leave your sidelights/tail lights on (not the reg plate though)
Checked in both my Mk2 and works Mk2.5 and the warming tones originate from the dash, somewhere behind the Speedo cluster.
I'm getting the idea that the sounder module is part of the cluster itself.
TDCiST
cant this also be turned on/off with IDS... i'm sure on that ELM Config program you can turn it on/off maybe someone has done that...
Full Colour Version: Headlight warning
