Full Version: Lambda sensor help!
Braders
Hi, I found out what is causing the engine managment light too come on my car, its the lambda sensor.
I was wonderin how much one of these would cost and if I could fit it my self. If so how do I do it?
Its the pre cat lambda sensor on a focus st170 54 plate
Cheers people
[quote name='Braders' post='36784' date='Aug 11 2009, 12:11 AM']Hi, I found out what is causing the engine managment light too come on my car, its the lambda sensor.
Cheers people[/quote]
your looking at around £42 plus delivery from online automotive, although i would get the part number of the old one if you can and give them a call to double check. failing that have a look on ebay
[url="http://www.onlineautomotive.co.uk/product_details.php?search_type=P&pr_id=50323&se_pc_id=2&se_sc_id=29&se_ft_id=1&se_ma_id=22&se_mo_id=306&se_es_id=23&se_bt_id=12&se_yr_id=55&se_pr_ref="]http://www.onlineautomotive.co.uk/product_...&se_pr_ref=[/url]
you could fit this yourself, not a difficult job providing the old one comes out.
Braders
[quote name='stef123' post='36822' date='Aug 11 2009, 12:01 PM']your looking at around £42 plus delivery from online automotive, although i would get the part number of the old one if you can and give them a call to double check. failing that have a look on ebay
you could fit this yourself, not a difficult job providing the old one comes out.[/quote]
thanks mate, price doesnt sound too expensive lol, very happy with that,
but how would i remove the lambda sensor, i looked at it last night and i can unplug one end of it but the actual sensor which plugs into the cat im not too sure about, i didnt wanna force it just in case i damage the cat or something
[quote name='Braders' post='36847' date='Aug 11 2009, 02:10 PM']thanks mate, price doesnt sound too expensive lol, very happy with that,
but how would i remove the lambda sensor, i looked at it last night and i can unplug one end of it but the actual sensor which plugs into the cat im not too sure about, i didnt wanna force it just in case i damage the cat or something[/quote]
yep i thought the price was reasonable, there are genuine ones on ebay for a whack more.
my advice would be to give it a good soak with some wd40 and leave it overnight if you can. sometimes a rag soaked with it and wrapped around the sensor may help too.
you should get away with using a 22mm ring spanner on it. if it doesnt come free then it may require some gentle heat from a blow torch.
if it does come out, a little bit of copper grease on the threads before you put it back in is a good idea. the new one doesnt need to be super tight either, just nip it up and it will be fine
Full Colour Version: Lambda sensor help!
