Full Version: Warning light ESP
Con Rod
Hi Folks,
Can any experts out there please comment on my "Ford Direct" Focus estate 4 years old 36,000 miles having the esp light on all the time.
This came on over night just after fourth service, can this fault be created by a dealer as I refused some work that they recommended.
eg front pads 90% worn even though all four pads had a minimum of 3mm of lining!
Error code 1288 and quote for repair approx £1150 for new ABS unit.
Is the whole unit faulty or could it be just a simple fault within?
The dealer who did the diagnostic asked if the car had been flashed?
I think the unit is behind the battery box, are there cheaper units out there and can it be a DIY job?
Really appreciate your time and comments on this issue, hope the ABS still works !!
Many thanks
gaz6076
The fault cant really be created by a dealer, but if they've had the wheels off during the service (which they should have) they could have disturbed a sensor or damaged something to do with the abs
What engine is it? Can you shed any more light on the error code?
Con Rod
Thanks Gaz6076 for your reply,
Engine 1.6 petrol Duratec.
Ford main dealer charged me £86.25 for the diagnostic, the car was back outside in less than half hour !!
Quote from technicians sheet:-
"Investigated into ESP light on placed on IDS & followed guided diag found fault code 1288 brake pressure control, advised new ABS module & valve block".
A few weeks before the light coming on the yaw sensor (near to steering column, I think) was heard clicking far too sensitively, I first thought that this could be the fault if the yaw sensor was faulty?
The car was OK when parked up at night but the light came on immediately on start the next day. ESP switch has no effect.
Fault appeared about 1000 miles after service, also stated dirty brake fluid at service if this means anything? however now replaced.
Cheers for your help, Thanks.
gaz6076
I'm not fimillar with the yaw sensor so I couldn't say if the clicking could be the cause. Although the yaw control system would be part of the ESP so you would think a problem with it could put the light on
I'll try find out more on the DTC that ford gave you. I think ford are going for the easy diagnostic there by just replacing the most likley part based on the code and with out doing anything else. You should of got at least an hour for your £86.
I wouldn't pay any attention to the dirty break fluid. Its a ploy to get more money form you. It's recomended you replace it every two years but it's just not necessary (personal opinion)
Full Colour Version: Warning light ESP
