Full Version: belt squealing
kev6474
can anyone help
I had a squealing from my belt drive Ive had the tension pully replaced and a new belt all was ok for a couple of days but the squealing is back its not as bad more of a squeaking now than a squealing and does go away after a while when it happens it squeaks when idle nad when driving
its an 2002 1.8 turbo diesel
gaz6076
[quote name='kev6474' post='37758' date='Aug 17 2009, 08:14 PM']can anyone help
its an 2002 1.8 turbo diesel[/quote]
Probably some oil or similar on one of the pulleys or the belt
kev6474
[quote name='gaz6076' post='37807' date='Aug 17 2009, 09:56 PM']Probably some oil or similar on one of the pulleys or the belt[/quote]
Thanks for the reply will give it a try
Big Bob
[quote name='kev6474' post='37809' date='Aug 17 2009, 10:14 PM']Thanks for the reply will give it a try[/quote]
I think you may have misunderstood the previous reply, you may already have oil on the belt causing it to slip, do not put oil or wd40 or such onto your drive belts. If you suspect slip and the belt is correctly adjusted, then try a little talc or french chalk on the belt & pulleys, it will roughen the surface to give more bite, you will probably need new belt anyway.
kev6474
[quote name='Big Bob' post='38063' date='Aug 18 2009, 11:54 PM']I think you may have misunderstood the previous reply, you may already have oil on the belt causing it to slip, do not put oil or wd40 or such onto your drive belts. If you suspect slip and the belt is correctly adjusted, then try a little talc or french chalk on the belt & pulleys, it will roughen the surface to give more bite, you will probably need new belt anyway.[/quote]
Thanks for the reply bob
the belt is only three days old the noise is a squeaking from the pulleys the belt doesnt look like its slipping when first started the noise is there when idle and when driving it first disapears when idle and after a short while when driving the noise then goes completly will try the talc
thanks again
kev6474
just thought id put an update on for anyone else with this problem in the end the new tension pulley was a faulty one had it replaced again its now been a week and no squeak
Full Colour Version: belt squealing
