Hi chaps, I need some help. My Dash clocks all gave up last week so I did some research and found there was a known problem with them intermittently failing and that the only cure was a £150 repair, New for daft money or second hand from a breaker.
I went the breaker route and bought a set for £20. I checked the part number of my old clocks against the replacements and it was identical so I was happy that they would work. However, when I fitted them I found that the ABS and brake warning lights wouldn't extinguish. I think the doner vehicle must have had ABS and as my vehicle dosn't so its showing a problem as it should. My question is, Can my ford dealer turn off the ABS function on the clocks using the diagnostic connector.
Thanks in advance.
