Just got my car into the 1st mot since i had it :-(
Failed on
Nearside Rear joint to flexi Brake pipe seriously damaged (found during steering lock to lock check) (2.2.D.1b)
Nearside Front Track rod end ball joint has excessive play (2.2.B.1f)
Offside Rear Coil spring incomplete (2.4.C.1a)
Offside 1x front to rear Brake pipe excessively corroded (3.6.B.2c)
£120 for parts £100 for labour and the mot fee £54 is that a good price?
altogether not good news the following advisory too
Offside Front Tyre worn close to the legal limit (4.1.D.1)
Nearside Rear Tyre worn close to the legal limit (4.1.D.1)
Nearside Front Brake pipe slightly corroded (3.6.B.2c)
1x front to rear Brake pipe slightly corroded (3.6.B.2c)
Offside Rear Brake pipe slightly corroded (3.6.B.2c)
Offside Front Anti-roll bar has slight play in a ball joint (2.4.G.3)
Front Brake disc(s) slightly worn (3.5.1h)
Nearside Rear Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.3)
Offside Rear Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.3)
Advise rear No plate
I reckon i can do all the advisory stuff myself exept for the brake pipes and teh roll-bar aint got a clue as to what to order for these or what bits are going out soon, any advice would be great
