Full Version: P2008 Intake Manifold runner control circuit
Ford Owners Club - Ford Forums > United Kingdom - General Ford Discussions by Model > Ford C-Max Club
coxie
Hi I have a 1.8 Ford C-MAX on a 53 plate, which has a intermitant fault code P2008 Intake Manifold runner control circuit / open bank 1. I have had this reset twice but it keeps coming back, and when the Engine warning light come on the car becomes slugish and will not pull away properly. Can anyone tell me what is a Intake Manifold runner control circuit and if I can be change without going to a garage and how much?
Thank you
Dave
Harv
[quote name='coxie' timestamp='1250877144' post='38620']
Thank you
Dave
I had exactly the same symptoms as Coxie. In my case the problem turned out to be the solenoids located top right of the engine which control (using manifold vacuum) the airflow in the inlet manifold. As there are two identical solenoids, I switched them over to see if the fault changed, and it actually went away so I presume one of the valves is not monitored. As least my intermittent P2008 fault had gone.
I replaced both solenoids with a Engine Air Shutoff Control, Ford part no 1357313, cost £61.78
Hope this help somebody
