Dennis
August 25, 2009, 2:26 am
I`ve posted this in the Fiesta Forum `cause i didn`t realise there was a specific wheel one. Just in case this get`s better coverage what i`m after is fitting wider STEEL wheels to my 2007 Fiesta van. Anyone know if there are some off another car that will fit ?
vinnyvangough
August 25, 2009, 3:53 am
You can also use Peugeot wheels, although they are not exactly wider.
The wheel offset is different but the fitment is very similar. I used to run Peugeot wheels on my Escort van all the time. As the offset is different, it makes the wheel sit further out, giving you a wider "track". This works fine but it will cause a little bit more wear on your lower arm bushes. But handling is improved by a long long way
