Full Version: Diagnostic results
escotty1976
Just had the results of my diagnostics, they have recommended throttle body cleaning and replacing the 02 sensor, does anyone know if this sounds right as regards to the issues with my car , revs sticking, eratic temp, high fuel consumption and a running a bit lumpy when idle occasionally ?
jedamotorsport
[quote name='escotty1976' post='39475' date='Aug 26 2009, 03:37 PM']Just had the results of my diagnostics, they have recommended throttle body cleaning and replacing the 02 sensor, does anyone know if this sounds right as regards to the issues with my car , revs sticking, eratic temp, high fuel consumption and a running a bit lumpy when idle occasionally ?[/quote]
just remove the t/body,get it on the bench and fire carb cleaner all over it,prolly the butterfly sticking ect ,this will remove all the crud,then give it a good wipe over.
I would then remove the iscv and do the same,think this will sort all your problems out.
Both get tarnished over the years and if not checked will gum up.
02 to me would not be a problem that needs addressing.
J
Full Colour Version: Diagnostic results
