Full Version: mondeo fault code p2263
jdw66
Any ideas what this points to ? all i know is it is turbo boost system performance,Turbo? car is now in limp mode i have a obd reader this is how i got the code but i dont want to erase it so i can show mechanic if need be.Thanks
the two common faults for this code is the egr valve is stuck open. you can remove and clean this -http://fordwiki.co.uk/index.php/Main_Page ( check out the egr valve clean under the mondeo section)
or the electronic turbo actuator return arm is siezed due to a build up of carbon on the turbo vanes, you can check this by seeing if you can move the little arm by hand when you remove the clip on the arm. but this is unlikely unless you have mega miles on the car. i would try the egr first.
jdw66
I had the egr and inlet manifold off a few weeks ago and gave them a good cleaning still had juddering and seemed to still be smoking,do you think it could be split in boost pipe from egr to intercooler?. Only 72k with full service history how easy is it to look actuater arm?.Could i have a faulty egr valve?
juddering at around 1800rpm and black smoke are symptons of a split intercooler pipe.
jdw66
Your were spot on mate intercooler pipe had a 3 inch split relaced it still smoking but no judders hopefully it will clear after a good run out.Thanks again all !!!!!
Full Colour Version: mondeo fault code p2263
