Full Version: Replacing Shocks - '96 MK1 Mondeo
Daveyraveygravy
Hi all - I've had a late MK1 mondy for 2 years and up until now its given excellent service - but the drivers side shocker has started leaking, so i've bought a new front pair (i'm reasonably handy with the spanners) I took the old one off, rebuilt the strut with the thrust bearing, upper spring mount etc - all good. So I put the strut onto the car - bolted it into the hub no probs, [b]BUT[/b] the threaded top part of the shock (with the allen key fitting inside) and the 'retainer' nut sits too high - so when I open up the bonnet to put the little round rubber & metal plate on top of it - the 'little round rubber/metal bit'
is about 3-4mm about the suspension turret - surely it should just rest on it nicely. I tightened up the first reatiner nut to the specified torque setting - i'm a bit perplexed as to what I can do - any ideas anyone?
covlad1987
[quote name='Daveyraveygravy' post='43583' date='Sep 19 2009, 11:08 AM']Hi all - I've had a late MK1 mondy for 2 years and up until now its given excellent service - but the drivers side shocker has started leaking, so i've bought a new front pair (i'm reasonably handy with the spanners) I took the old one off, rebuilt the strut with the thrust bearing, upper spring mount etc - all good. So I put the strut onto the car - bolted it into the hub no probs, [b]BUT[/b] the threaded top part of the shock (with the allen key fitting inside) and the 'retainer' nut sits too high - so when I open up the bonnet to put the little round rubber & metal plate on top of it - the 'little round rubber/metal bit'
is about 3-4mm about the suspension turret - surely it should just rest on it nicely. I tightened up the first reatiner nut to the specified torque setting - i'm a bit perplexed as to what I can do - any ideas anyone?[/quote]
sounds like the spring not seated right
Daveyraveygravy
Thanks for your help - I checked the spring when I put it inro the strut - its seated in both the upper and lower mounts correctly. This photo might be able to show what I mean a little more clearly. Its almost as if the top of the shock needs to be pushed down slightly, but then it will only pop back up, surely? The whole design seems a bit lax to be honest...Any more ideas anyone?
MARTIBHOY
Could that be the wrong nut youve put on first?
Maybe the 1st one is "smaller" then you put the plate on with the bigger nut?
covlad1987
[quote name='MARTIBHOY' post='43866' date='Sep 21 2009, 08:32 PM']Could that be the wrong nut youve put on first?
Maybe the 1st one is "smaller" then you put the plate on with the bigger nut?[/quote]
i agree the smaller nut needs to go on first
