[quote name='001james' post='44770' date='Sep 28 2009, 09:26 PM']Hello everyone im a newbie here and i just wondered if anyone can help me,. ive just got myself a 1998 mondeo 1.8 GLX petrol,all is fine except my key fob isnt working for the central locking,ive put new battiers in it ( not sure if i have them the right way round tho ) but it still isnt working ?
. any advice would be helpful....thanks guys
had the same problem changed battery aswell my last resort was resetting the ecu that fixed the problem
The easiest way to reset the ECU is to remove fuses 4 and 11 from the fusebox next to the battery in the engine bay and leave the car for about 15 minutes. (This is the case for the Mk1 and Mk2 Zetec engines. Check your user guide for other models) Identifying the fuses means that you will not have to reset your clock or radio, which you would have to do if you were to disconnect the battery.
When the fuses are re-inserted, your car's ECU will relearn according to how you drive your car. This can take anywhere from a couple of hours to a week or so. However, the following steps might speed the overall process up:
Start the car and leave it idling for 15 minutes or so... it will probably stall a couple of times, but it'll soon level out at just under 1,000 revs
Then take the car out and drive it as carefully as you can for an hour or so
Finally, take it out onto the longest road you can find with a national speed limit and open the throttle up
Mk3
The procedure for the Mk3 is slightly different, according to the Haynes manual. They recommend doing the following once the PCM (or ECU) has been disconnected for a while:
To allow the PCM to relearn, start the engine and run it as close to idle speed as possible until it reaches its normal operating temperature Then run it for approximately two minutes at 1200rpm Next, drive the vehicle as far as necessary - approximately 5 miles of varied driving conditions is usually sufficient to complete the relearning process. Don't forget to reset your one touch windows and change the clock to the correct time!
Note, this mod will also reset your stereo if you disconnect the battery to reset the ECU, so if you dont have a code for it, now is a good time to get one!
