domerj
September 29, 2009, 12:47 pm
Wifes ka turn ignition key hear fuel pump then nothing,she called the AA out he just bumpstarted it. said it could be startermotor but no clicking rocking in gear makes no difference.
Could it be imobiliser/relay problem?
Turn ignition on imobiliser light on clock goes out but nothing dead any ideas??
delboy
September 29, 2009, 1:53 pm
try putting the battery on charge
if it bump starts then it's not the immobiliser.
get it going & give it a good drive about without lights or radio on
then stop the car turn off (do outside house)
then re-start it
if it dont start then i would check relays or remove battery & replace it or charge it overnight
sounds like battery to me m8.
had same a while back
domerj
October 12, 2009, 2:53 am
[quote name='delboy' post='44883' date='Sep 29 2009, 08:03 PM']try putting the battery on charge
then re-start it
had same a while back[/quote]
thanks delboy recharged battery but still wont start heard theres a couple of relays under the bonnet anyone know there location?
October 12, 2009, 12:51 pm
start by checking the connections on the starter motor, sounds like it might be the exciter wire. its the very thin wire that connects to the solenoid.
i would also check you get a voltage on the exciter wire when you turn the key to start the car.
October 13, 2009, 1:19 pm
also check the ignition relay
ka won't start
