Hello all
I thought i found the fix to the car with the pcv nope it came back today to bit me on the arse
i found a way though if u take the one pipe off the head underneath manifold and put ur finger over it or over the nozzle the enginwill try and stall like it does when i am slowing down but it wont stall fully it will realise then kick itself back upto life just like it normallydoes look at the drawings below
Wht doyou thinkif i get 3 small little filters similar to the ones below with a bit of hose on and attach to the head
when u drive the car with out the pcv valve in the car willrunandidle about 1,300rpm then drive fine shriek a bit like alternator / air con trying to kick in and then be fine but when u slow down and put foor down on clutch it will go to 3000rpm then slowlyidle down to 1,300rpm again this does not bring on a eml light but the stalling thing wont happen thing is i will screw my engine running it like this
thethre filterone will sit on the one nozzle one side of pcv valve then other on otherside of pcv then on on the pcv valve itself WILL THIS WORK?
FILTERS X 3 OF THEM
[img]http://www.ruckuslife.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/6/2/62-1320.jpg[/img]
MY PCV VALVE
[img]http://photos-a.ak.fbcdn.net/hphotos-ak-snc1/hs218.snc1/8525_152387012321_577987321_2793554_2542474_n.jpg[/img]
THE THREE HOSES ALL JOIN TOGETHER LIKE THE ONE IN THE PICTURE BELOW VIA A 3 WAY HOSE CONNECTOR
THIS IS MY VERSION OF THE CREATING MY OWN PCV SYSTEM TO STOP MY ENGINE STALLING WHEN SLOWING DOWN WELL ATTEMPT I SHOULD SAY (sorry about caps)
[img]http://photos-g.ak.fbcdn.net/hphotos-ak-snc1/hs218.snc1/8525_152387022321_577987321_2793555_2251523_n.jpg[/img]
THE PCV VALVE SITS IN THE LOWER PART O THE MANIFOLD BOX NOT THE ENGINE BY THE WAY DRAWING SLIGHTLY WRONG
Can anyone help on this matter as this is driving me insanennow as i have found the problem now is trying to find a fix for it
any help or comments be much appriciated
cheers
matt
