Domz78
October 19, 2009, 8:05 am
on here 4 a m8 he has st24 mondeo on a p but his clutch keeps on coming then going is clutch gone or the slave were stuck any help many thanxx lads
gaz6076
October 21, 2009, 9:08 am
Bit more detailed info would help...
Sounds more like the slave cylinder to me from what youve given me to go on
chris bowman
October 22, 2009, 4:33 pm
[quote name='gaz6076' post='46846' date='Oct 21 2009, 03:18 PM']Bit more detailed info would help...
Sounds more like the slave cylinder to me from what youve given me to go on[/quote]
only problem is clutch slave is inside bell housing between engine and gearbox meaning similar labour as clutch. check condition of clutch at same time. might be worth replacing while ure in there!
gaz6076
October 23, 2009, 2:34 pm
If it is a concentric slave then which ever part is the problem you would be as well as changing both as Chris says
