Pogo
June 9, 2008, 3:29 pm
Hi, I'm another Newbie to the Forum, so Hi to All.
I have a 2003 Mondeo TDCI with Xenon headlights. The one dip beam bulb has blown, but is it just a simple change of the bulb at home or do I need to take it to a dealer?
Many Thanks[/font]
Steve
June 10, 2008, 2:55 pm
[quote name='Pogo' post='1653' date='Jun 9 2008, 09:29 PM']Hi, I'm another Newbie to the Forum, so Hi to All.
Many Thanks[/font][/quote]
Should be just a bulb
Col_Tubbs
June 29, 2008, 4:34 pm
Which side as gone ??
If it's the LH side then the system will be needed to be setup again at about £100 ish a pop plus bulb which Ford will charge about the same again.
Pogo
July 7, 2008, 3:03 pm
[quote name='Col_Tubbs' post='1955' date='Jun 29 2008, 10:34 PM']Which side as gone ??
If it's the LH side then the system will be needed to be setup again at about £100 ish a pop plus bulb which Ford will charge about the same again.[/quote]
What do you mean set up?
bn8959
October 23, 2008, 12:36 pm
Did it turn out to be just a bulb?
My left hand side bulb blew. I have just replaced it with a new bulb (Osram D2S), but it still dosent work. I did various swap tests and it appears to be the metal box behind the headlight (the ballast), which is not working, as if I swap it for the right one, it works.
Col_Tubbs, you refer to a 'reset', Ive noticed there is a far amount of circuitary in the ballast box, does that need resetting, or has that simply blown as well? If so, I guess I will need to replace it.
Time is against me, because my car is booked in for a MOT in a couple of days and I dont really want to pay Ford £££s to fix it.
Thanks!
Ben
Pogo
October 28, 2008, 6:02 pm
[quote name='bn8959' post='6613' date='Oct 23 2008, 05:36 PM']Hi,
Thanks!
Ben[/quote]
Hi Mate,
Yes it was just the bulb in the end, not sure what was meant by 'resetting'
Xenon Headlights
