Right the problem is a friends focus had hunting on idle problems when the engine was warm so done a full service on it other day to find that the spark plugs were oily no 1. plug not too bad but as you went along they got worse no.4 spark plug even oiled the 16mm socket.......?
Any help to what is causing this oil on plugs would be great as im getting a lot of different feed back from rocker cover gasket to head gasket and worn rings.....? Since putting the new plugs in the idle problem has gone but it has only been 2 days of driving...
Its a 1.6 zetec se which has been regualry serviced and has only covered 79,000 miles which i thought aint a great lot....
So any help or ideas welcome.
