crazyhazyj
November 25, 2009, 7:57 am
[quote name='InstructorPiggy' post='50658' date='Nov 25 2009, 02:38 PM']Maybe so, need to ensure which sensor and bank tho.
There be a sensor per bank, and maybe even pre cat and after cat Lambda sensors.
Get a multimeter on the signal wires and check them.
It is likely it is the fault, bt need to check the signals from each...once warm always good, at idle.
Ensure good switching between 0.1 and 1v.
Piggy
thanks for that mate will try that and see what happens do you know a good website for cheap ford parts as the main dealers are as you would guess very expensive
