simon_20
November 28, 2009, 11:16 am
I need to change some bulbs that light up the heating controls and window switch and also my lights switch
Any one know how to get the knobs out to replace bulbs behind?
Many Thanks.
SierraYankee99
November 30, 2009, 1:22 am
Pop the radio out and theres 4 screws behind it. Take these out and the console pulls out. Good firm pull needed. Then you can unplug all the multi plugs. The heater controls are slightly different to remove. Turn the knobs to the left and then click the release catches and remove. These could be hard to remove as they are attatched via cables to the vanes that control the heaters. You might be lucky and be able to get to the bulb holders without actually removing them at all, just remove the multi plugs to get a bit more movement on the console. Good luck with this.
simon_20
November 30, 2009, 3:07 pm
Thank you i shall give it a go many thanks.
