Full Version: Windows
Ford Owners Club - Ford Forums > United Kingdom - General Ford Discussions by Model > Ford Puma Club
sloopy
[size="4"][/size]
My Nephew's Puma, an R reg, 1.7, petrol, manual, has a really, really annoying problem.
The electric windows switch which operates both windows ceases to work on a regular basis.
Replacing the button-switch has always cured the problem, along with a new 30 amp fuse.
My nephew is very heavy-handed and so the push switch always gets broken.
THIS TIME, replacing the switch hasn't worked.
What is there at the present is a blue-block connector, that goes into one recoeptor on the underside of the switch, and then 4 spade terminals which fit into the other receptor.
These spade connectors carry 4 wires- White, Double Orange, Yellow and Black.
The 4 terminals inside the receptors are numbered, 1 , 2 and 3 on the top row, and 7 on the bottom.
Question 1 is:
What is the correct wire-colour sequence for the spade terminals?
Question 2 is:
As the blue-block seems to be Iffy, is it possible to extract the wires from the blue-block, attach spade terminals to the wires,and connect them to the receptor terminals, thus getting rid of the Iffy blue-block?
Question 3 is:
Is there a different fault altogether, causing the non operation?
I do so hope you can help.
Best wishes
[quote name='sloopy' date='29 November 2009 - 01:10 PM' timestamp='1259499645' post='51421']
[size="4"][/size]
Question 1 is:
Question 2 is:
Question 3 is:
Best wishes
ive no idea but when i have these wiring issues i tend to go to a scrapyard and have a look i think i would cut the block off another puma with wiring attatched a good 2 inches should do it then solder it to the original wires and use heatshrink on it to protect the wiring
thesilverfox
You may wish to update the thread title - I was expecting something a little different ... !
Gazjs
[quote name='thesilverfox' date='03 March 2010 - 08:20 PM' timestamp='1267647051' post='68609']
I too noticed this earlier but thought i would let it go unnoticed in case i was being slightly daft and it was correct :lol:
Full Colour Version: Windows
