jocojohn
December 5, 2009, 8:16 am
Can anyone help with a problem my son has with his 99 reg 1.6 Focus. The exhaust heat shield over the rear silencer box has come away from a couple of the fixing bolts and makes a terrible noise when going over even the slightest of bumps in the road.
As a last resort we could drill more holes into the car floor and fit self tapping screws but has anyone got an easier solution.
Thanks, John
ps. we have tried bending the shield into various positions towards and away from the exhaust but we cant quite silence it completely.
December 5, 2009, 11:49 am
remoe the original fixing bolts and replace with large washers this will sort it out had the same issue and done that all sorted now
December 5, 2009, 12:37 pm
i also had a similar problem but mine was so bad i drilled a few holes and secured with pop rivets and large washers
December 5, 2009, 2:19 pm
[quote name='stef123' post='52584' date='Dec 5 2009, 06:47 PM']i also had a similar problem but mine was so bad i drilled a few holes and secured with pop rivets and large washers[/quote]
seems to be a common thing on all cars ive had if you do drill any holes then get waxoyl and underseal and give the holes a good dousing with that before or after you fit the bolts
