Full Version: Engine Misfire
Budgie650
After servicing my 52 plate Ka,changed plugs,oil change,air filter change,the engine now misfires when putting your foot down,could it be a dud spark plug,or the HT leads.
roger4321
[quote name='Budgie650' post='54418' date='Dec 15 2009, 12:17 AM']After servicing my 52 plate Ka,changed plugs,oil change,air filter change,the engine now misfires when putting your foot down,could it be a dud spark plug,or the HT leads.[/quote]
Did you check the gaps on the plugs when fitting them?
InstructorPiggy
plugs now come ready gapped...could be got the wrong plugs!
Did you get some grease on an electrode maybe?
or the HT leads not quite clipped on?
Budgie650
[quote name='roger4321' post='55612' date='Dec 20 2009, 04:25 PM']Did you check the gaps on the plugs when fitting them?[/quote]
yes checked the gaps with feeler gauges
Budgie650
Yes i set up the gaps with feeler gauges
Budgie650
[quote name='InstructorPiggy' post='55615' date='Dec 20 2009, 04:30 PM']plugs now come ready gapped...could be got the wrong plugs!
or the HT leads not quite clipped on?[/quote]
Fitted the right plugs,no grease on the electrode,and the HT leads are all fitted correctly.
InstructorPiggy
Does it miss at idle???
If so, remove the leads one at a time as its running, (then replace obviously!) and see which one makes NO difference to the misfire...then turn engine off and inspect plug...see what colour it is, and look VERY carefully at the ceramic...may have the tiniest of cracks!
what make of plugs did you use?
also, if it does miss at idle...take it to the darkest place possible, lift bonnet, turn all lights off and look out for any little lightening jumps from the Ht leads/coil to the engine :)
Piggy :)
Budgie650
[quote name='InstructorPiggy' post='56250' date='Dec 22 2009, 07:51 PM']Does it miss at idle???
Piggy :)[/quote]
Engine does not misfire on tickover,have removed plugs one by one all nice colour no obvious cracks on ceramic,could i have a dud spark plug
aquila
Last time I had a misfire it was the ignition coil ;)
Full Colour Version: Engine Misfire
