georgeb22
December 21, 2009, 7:58 am
Hi I have an 04 Ford Focus TDCI GHIA ESTATE, I know the weather is cold but my front and back water jets are not working, not even the usual noise you get when depressing the relevent butttons, both wipers work, just wondering whether they run off a fuse?
kind regards
Chris
thesilverfox
December 21, 2009, 8:07 am
[quote name='georgeb22' post='55736' date='Dec 21 2009, 02:08 PM']Hi I have an 04 Ford Focus TDCI GHIA ESTATE, I know the weather is cold but my front and back water jets are not working, not even the usual noise you get when depressing the relevent butttons, both wipers work, just wondering whether they run off a fuse?
kind regards
Chris[/quote]
If you press the washer button, regardless of noise or juice coming out, do the wipers do their sweeps after pressing the button? If not, then inclined to think 'fuse'. If the wipers do sweep, I'd wonder if the pump is the issue.
bigjock
December 21, 2009, 8:15 am
i have had this problem with both my cars the past 4days its defo due to the weather as they work again after 15mins or so of driving must be frozen over.
December 21, 2009, 9:20 am
ive had the same and its the water freezing in the pump add 15 drops of vinegar white vinegar to the wash bottle also make sure you have at least 50/50 mix of pure screenwash and water the temp at night is around minus 7 sometimes i removed the pump and the water in the pump was frozen if it was in the bay it would defrost quicker but ford decided to shove it inside the wing under the liner giving it very little weather protection my dads nissan was the same as well as my sisters rover just the cold mate
bigjock
December 21, 2009, 9:40 am
good tip with the vinager will give this a try. i have 100% screenwash and mine is still freezing lol! cant be good for the wipers tho all this dry friction, makes me cringe! lol
InstructorPiggy
December 21, 2009, 11:03 am
100% screenwash...I don't mean to call you silly....but is it premix screenwash...like from halfords?? Or are you pouring undilluted screenwash in??
Mine partly froze today...
Just a thought, if you use fairy liquid of any sort in the screenwash bottle it has a tendency to turn into gunk and block the fliter just before the pump...but if you got no noise whatsoever...gota be pump froze!!
thesilverfox
December 21, 2009, 11:08 am
[quote name='InstructorPiggy' post='55783' date='Dec 21 2009, 05:13 PM']100% screenwash...I don't mean to call you silly....but is it premix screenwash...like from halfords?? Or are you pouring undilluted screenwash in??
Fairy liquid tends to rot the rubber tubing - it's quite acidic really!
December 21, 2009, 11:51 am
it was my dads advice with the vinegar old school trick and its worked for me had no probs today you need 70 percent undiluted wash with 30 percent water and 15 drops of vinegar as its diluted it wont do any harm i was the same i checked every fuse thinking that was the prob my old man was a ford nut and he said its been the same with every one they ever built that the pump freezes due to where it is located
bigjock
December 21, 2009, 11:56 am
im using asda's finest screenwash £1 gets you 2.5ltrs of pure liquid gold. says you can use it undiluted in severe weather conditions (i think we can safely say thats now) and that it contains a freezing inhibitor (ooooh).
InstructorPiggy
December 21, 2009, 12:26 pm
[quote name='bigjock' post='55825' date='Dec 21 2009, 06:06 PM']im using asda's finest screenwash £1 gets you 2.5ltrs of pure liquid gold. says you can use it undiluted in severe weather conditions (i think we can safely say thats now) and that it contains a freezing inhibitor (ooooh).[/quote]
i use same!
no freezing!
bigjock
December 21, 2009, 12:29 pm
[quote name='InstructorPiggy' post='55836' date='Dec 21 2009, 06:36 PM']i use same!
no freezing!
some tramps probo pissed in me tank then, never mind be warm again in 6months!
bt_cav
January 7, 2010, 6:05 pm
Good tip about the vinagar, gonna give it a go as im sure my water is frozen, I had almost neat halfrauds screen wash in but say no more. I have been told that Aldi's screen wash is really good it goes down to -60 or so it says on the label.
One thing i was wondering about was when do the heaters come on in the washer jets? I assumed they would come on the front heater was on, and the rear jet with the rear window heater???
UPDATE 01:52
Just nipped out to tesco and bought some white vinegar poured in a small amount went a short slow run round about to let the vinegar do its magic and introduce some warmth but not a sausage, guessing I have a watter bottle shaped lump of ice
I dont think there was much fluid in the bottle so I have brought in about a litre of screen wash into the house (out the cold) and will put it in tomorrow and hope for the best.
cyb
January 8, 2010, 3:36 am
[quote name='bigjock' post='55839' date='Dec 21 2009, 06:39 PM']some tramps probo pissed in me tank then, never mind be warm again in 6months!
Hate to tell you this but urine is probably one of the best de-icers going, not that I would advise you use it
bt_cav
January 8, 2010, 5:18 am
[quote name='cyb' post='58880' date='Jan 8 2010, 09:46 AM']Hate to tell you this but urine is probably one of the best de-icers going, not that I would advise you use it
Intresting, how did you discover this?
bt_cav
January 8, 2010, 5:55 am
just been to Aldi's and asked the lady for screenwash she hasnt seen it for a long time, perhaps its Lidl, howver they are sold out, normally eather of their own brands are good quality.
let us know if you find any
DeeBe
January 8, 2010, 9:54 am
I had the exact same problem, and its definitely the washer pump frozen. I too have just added some vinegar to my £1 ASDA screenwash! Jai'ho indeed!
Erm, maybe a stupid question, but does my car have heated washers???
January 8, 2010, 12:02 pm
[quote name='DeeBe' post='58942' date='Jan 8 2010, 04:04 PM']I had the exact same problem, and its definitely the washer pump frozen. I too have just added some vinegar to my £1 ASDA screenwash! Jai'ho indeed!
Erm, maybe a stupid question, but does my car have heated washers???[/quote]
it can take a bit to defrost in this weather it was so cold at one point mine still froze up a bit dont be temted to put warm water in to it most screenwash you get says 50/50 for winter but pure undiluted for severe ide say minus 11 was severe weather
Bazza
January 9, 2010, 9:05 am
mine was frozen also,i managed to defrost it with warm water
i went to add my screen wash and now it does not work
checked all the fuses and all are okay
there was a strange smell
have i knackered the pump
bt_cav
January 9, 2010, 10:27 am
Hey DeeBe
My 1.6 focus 2004 has heated washer jets, not sure when they come on, not sure if they are wired up with the heated windows. Open the bonnet and look at the back of the jets I can see the wires on the back of the jets.
I had a look on line and found that the freezing point of vinegar is only -2 not sure how accurate this though, thinking of leaving a cap full of vinegar out side to see how soon it freezes.
Also I had a look in my Local Lidl and they are due to get screen wash that protechs down to -60. Hoping to have better weather or at least above freezing before then....
DeeBe
January 10, 2010, 5:25 am
[quote name='bt_cav' post='59089' date='Jan 9 2010, 04:37 PM']Hey DeeBe
Also I had a look in my Local Lidl and they are due to get screen wash that protechs down to -60. Hoping to have better weather or at least above freezing before then....[/quote]
I have seen some plugs and wires on the underside of mine too, hmm. I will be keeping a lookout for that -60 screenwash! Sounds like a problem solver to me!
Cheers bud!
January 10, 2010, 6:45 am
[quote name='DeeBe' post='59218' date='Jan 10 2010, 11:35 AM']I have seen some plugs and wires on the underside of mine too, hmm. I will be keeping a lookout for that -60 screenwash! Sounds like a problem solver to me!
Cheers bud![/quote]
all i can say is mine hasnt frozen since even though its been colder weather the nozzles did slightly but the actaul motor was buzzing away thats with the vinegar and about 70/30 soloution ive heard of lidls stuff but never been able to get my hands on it aldi had some similar stuff and it went like they were giving away free golden eggs so it must be good stuff
Bazza
January 10, 2010, 10:05 am
I pulled of the washer bottle
sure enough the pump had burned out
and was half full of ice
new pump fitted and filled with screen wash
i will try the vinegar trick aswell
