Full Version: Ranger pcd
Ford Owners Club - Ford Forums > United Kingdom - General Ford Discussions by Model > Ford Ranger Club
hitch
What PCD is the 6 stud ford ranger 2003/4 model please
macboatmaster
Here is your answer from the workshop manual. Hope it helps. Macboatmaster
TECHNICAL DATA
TD–14
General
Item 42 44
Size
Front 185R14C- 195R14C- 205R16C- 235/75R15
P235/75R1
P235/75R1
Rear
185R14C
8PR
195R14C
8PR
205R16C
8PR
105S
5 105S
5 106S
Front
Unloade
d
(Up to
full
passenger
180
{1.8, 26}
180
{1.8, 26}
180 {1.8, 26}
Tire Air pressure
Loaded
(Full
loaded)
200
{2.0, 28}
200
{2.0, 28}
ressure
(kPa {kgf/cm2, psi})
Rear
Unloade
d
(Up to
full
passenger
180 {1.8, 26}
Loaded
(Full
loaded)
450 {4.5, 63} 250
{2.5, 35}
240
{2.4, 34}
260
{2.6, 36}
Wear limit (mm {in}) 1.6 {0.06}
Wheel
Size 145J
145J
145
1/2J
166JJ 156 1/2JJ
Offset (mm {in}) 40 {1.57} 35 {1.38} 25 {0.98}
Pitch circle diameter (mm {in}) 139.7 {5.45}
Tightening torque
(N·m {kgf·cm, in·lbf})
Standard wheel: 89—117 {9—12, 65—86}
Styled wheel (166JJ): 118—147 {12—15, 87—108}
Wheel
and tire Runout limit (mm {in})
Horizontal 2.0 {0.078}
Vertical 1.5 {0.059}
Imbalance limit (g {oz}) 10 {0.35}
 One balance weight: max. 60 g {2.1 oz}.
 If the total weight exceeds 100 g {3.5 oz} on one side, rebalance after moving the tire around on the rim.
 Do not use more than two balance weights on the inner or outer side of the wheel.
hitch
so its a 6 stud 139.7mm
i was wondering because i was looking to fit some 6 spoke steel weller wheels, (like landrover defender style) but drilled to 6 stud, with some offroad tires
would it work do you recon?? or would the offset stick out to wide, as i have never seen a ranger with wide offroad tires always skinny offroad tires on standard rims, which are well hidden in the arches
Hitch
Full Colour Version: Ranger pcd
