kaka
December 29, 2009, 1:23 pm
hi everyone, just wondering if anyone has come across the same problem as myself on 06 plate 1.3 ka, car starts ok and drives till warm, then if you turn off ignition then try to restart - nothing, no dash lights, dead as the proverbial dodo, but wait around 5 mins and clicking noise from dash, turn key and back to normal but have to recode radio, suspect dodgy relay but not sure, any help greatly appreciated
Chris Ecc
December 29, 2009, 5:32 pm
If your re-coding the radio that means it is losing all electrical power, have you checked the battery for any damage or signs of wear and tear?
kaka
December 30, 2009, 4:24 am
[quote name='Chris Ecc' post='57041' date='Dec 29 2009, 11:42 PM']If your re-coding the radio that means it is losing all electrical power, have you checked the battery for any damage or signs of wear and tear?[/quote]
Hi Chris, thanks for your reply, forgot to mention that car had been into ford garage and had alternator replaced under warranty recently, have found negative terminal loose on battery, I guess i'll have to check everything the garage does from now on
