jay32
January 12, 2010, 3:15 pm
Hi all,
Recently bought a Mondeo LX TDDI, on a 51 plate. very happy with it so far.
When I purchased it, the previous owner had just given it a full service and new rear brake pads & discs. In the first week the handbrake was great, it only clicked 2 notches and it was on full. then it start coming right up about 5 notches and on a slope I have to leave it in gear. I asumed it needed adjusting hence joining this site for help off you guys, then tonight it was working fine again and only raising 2 notches???
Can anyone shed any light on this??
Jay
fester59
January 13, 2010, 6:44 am
[quote name='jay32' post='59717' date='Jan 12 2010, 09:25 PM']Hi all,
Jay[/quote]
Early Mk 3 Mondeos suffer badly with Rear Calipers / Cable issues
Usually Calipers sticking or failing Cables that come in 3 parts, one front to back of the Car and one to either side. It`s probably something to to with the Cables as the Calipers tend to stick on.
jay32
January 13, 2010, 9:33 am
[quote name='fester59' post='59777' date='Jan 13 2010, 12:54 PM']Early Mk 3 Mondeos suffer badly with Rear Calipers / Cable issues
Usually Calipers sticking or failing Cables that come in 3 parts, one front to back of the Car and one to either side. It`s probably something to to with the Cables as the Calipers tend to stick on.[/quote]
Thanks mate! will check it out
chris bowman
January 13, 2010, 3:56 pm
[quote name='jay32' post='59797' date='Jan 13 2010, 03:43 PM']Thanks mate! will check it out[/quote]
on a mkiii mondeo dont the 2 smaller cables at the back go very close to heat shields and quite often the heat causes the cables to stick?
January 13, 2010, 6:04 pm
if the car is still on the original handbrake cable, i would be wanting to change it anyway really. i done mine not too long ago on my 51 plate focus and its spot on now!
took me less than an hour, 10 mins to adjust. cost less than £30 for the full assembly. i would imagine its very similar on a mondeo
jay32
January 22, 2010, 3:58 am
If i slowly pull the handbrake up as im braking and nearly at a stop, It works fine!! but if I come to a stop and then apply the handbrake it doesnt work.
I think I will just change the cable and be done with it..
Paul D
January 22, 2010, 8:25 am
[quote name='jay32' post='61140' date='Jan 22 2010, 10:08 AM']If i slowly pull the handbrake up as im braking and nearly at a stop, It works fine!! but if I come to a stop and then apply the handbrake it doesnt work.
I think I will just change the cable and be done with it..[/quote]
might want to check as mkIII have two handbrake cables, best to replace both if this ia requirement
Handbrake adjusting?
